| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94239 01/10/2006 7:24 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Every truck I have owned with dual tanks switched the gauge along with the gas tank. You should be able to wire it through the switch or use a relay to switch, or add another switch to the dash so you can check the other tank level without switching the tanks.
