| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | How I found my worn guides was first with a auto stethascope locating the area of the noise. This put me right on the number four and 5 intake valves then by removing the spark plugs and rotating the engine by hand and watching the movement of the top of the valve as it went through it's lift cycle. When I removed the head off the truck and disassembled the spring off those valves it was very clear what the issue was. As soon as the valve came off the seat, the top of the valve could be wiggled 3/16" of an inch. Oddly enough the seats were still fine. The engine idled with 21" vacuum and had good compression too. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
