I'm using a '00 GMC/Chevy steering column in my '56 Burb and want to connect the steering column wires to the brake/turn signals lights and Hazard flashers. The OE wiring schematics routes the wires thru a Body Control Module (BCM) which I will NOT be using.
I'm not certain where to connect three of the eight wires so if someone can help me out :confused: .
The steering column has the following wire colors, pin number, and function:
-White A1 Stoplight switch
-Gry A3 ?
-Ppl A5 ?
-Dk Blu A6 Front right turn
-Lt Blu A7 Front left turn
-Lt Blu E1 ?
-Dk Grn E6 Rear right stop/turn
-Yel E7 Rear left stop/turn
