| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 72 up GM vehicles had disc brakes with a dual MC and a booster. Typically they also used a proportioning valve and had a built in residual valve. Disc brakes require more pedal pressure hence a booster would be the preferred set up. How a disc brake MC designed for use with a booster would perform without the booster would be speculative. Some aftermarket suppliers offer a kit with brackets, MC, & proportioning valve for use without a booster. I don't know what parts they use or how well they work. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
