Did you use new screws to hold the window frame to the regulator, if so the heads on the screws may be too big and are blocking the rollers in the track of the regulator. If I remember right, they should be counter sunk heads or very small.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
