| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | I was adjusting the free pedal and noticed that bolted to the inside of the frame is a U shaped bracket. On the top it has the spring for the brake pedal to return to proper height. The bottom part of the U has a hole for a spring but there is no spring.Betsy (1951)3100 has had the clutch pedal returning to about 3 inches( +-)below where the brake pedal does for as long as PA and I have driven it.Is there a return spring missing?? I think I see one in the picture on OCMP but black and white all blends in and can not tell.Thanks | | |
