1 members (5 Window 9434),
68
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I would guess they are similar to V8 side mounts and therefore can use a (modified) aftermarket cross member. Classic parts 79-405. May take a little "engineering" but you can do it... or this may give you more ideas. I don't know dimensions of 235 mounts and 37 truck frames. Don't know the tranny you are using but it will need a mount also.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
