| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | 52 pickup, Another welcome. As a new guy you need to learn to use the search feature in the header. If you type in temp. or temperature gauge you will get a number of posts which deal with trouble shooting, repair, and calibration of this gauge. As a sidebar, fuel and temp gauges (balanced coil type) work the same way. The senders are nothing but variable resistors. As the fuel level/temp goes up, the resistance goes down (usually). A number of gearheads lurk here just waiting to pounce on a truck/car problem you have.
