I stongly suggest you replace the wiring harness. They are not complicated and run about $150 (I think??)
If you are just making a repair, here's a wiring diagram with the wire gauge on it... Its for a 55, but should answer your question...
Hope this helps and welcome to the forum
wiring diagram
