| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year and configuration? do you really mean it will "not engage" or it will not DIS-engage? can you push the pedal down? does the truck try to move when you crank it with the pedal down? are you sure you used all the correct parts for your application? examine your work carefully to see what you've installed incorrectly, maybe you put the throwout bearing in backwards - you need to elaborate on the problem
Bill | | |
