i'd replace that coil with the correct one. then try totally bypassing the ignition switch by running a wire from the + terminal of the battery to the coil (+) & see whaat happens. btw the starter should turn when the key is in the "off" position, it just won't start from there.
robert
Robert French MY3800FIRETRUCK
