7 members (FrankenChevy, 3B, msmall, walter74, Stovebolt48, Shardean, 1 invisible),
63
2
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, nearly any manual trans will bolt to a small block if it has the correct bellhousing, the 700 has it's own 'bellhousing' built in, so you'd need a standard one to go with the trans, and the crossmember to support it, the stick trans doesn't use a 'trans mount' .... but why would you want to take out an overdrive??
Bill | | |
