Thanks for the pic Hoozat.These pics help a lot,but I am still a little unsure if the mounts fasten to the frame or just sit on the frame.If they fasten to some kind of bracket ,then I don't have it.I have new mounts on the way as the rubber is gone on my old ones and I just have the metal part on the bell housing.I am also missing some kind of bracket for the peddles.My peddles are mounted on a bracket withe master cylinder,but it looks Like I need another bracket to fasten it to what ever it bolts to.maybe the 3 bolts in the back of the bell housing? GWWirth I am also using singal stage urethane,But the fenders and running boards will be a darker blue metallic ;so I plan on using 2 stage urethane ( base coat clear coat)
