Classic Parts, they seem to fit and work, i made a couple of spacer plates to put in but ended up that i added 4 washers between the plates on each side at each bolt to take up the space (new bolts of course), doing a complete brake job also so the real test will be when i get it all back together. I am not sure i would recommend buying these as the ones a took off even though they are 63yrs old fit together better.
