Anyone have a picture of the brake pedal spring linkage system on the firewall side of the cab?
This would be a set of springs that connect to the brake pedal and help it return to a neutral position. I believe its somewhat similar to the one used for the clutch pedal. Jim Carter offers them, part # MEB113.
Just getting to my brakes and noticed them online when i was looking at parts. Not sure where they go tho as my truck was missing them when i got it.
Also this is in regards to a 1954 3600, with a brake release pedal, as opposed to a lever, in the cab.
Much thanks,
Chooglin
