7 members (55shaker, 1955 1 Series, Bill Hanlon, Oswald, Greg_H, Ponchogl, Shade Baby),
140
2
Mod | | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | No problem..... I have a column shift type steering column from a 78 Chevy van in mine - hooks up OK to the linkage on my TH350. Have a few Borgeson universals to route DD type steering shaft around exhaust and engine mount, and into the steering box. Have a Saginaw type PS pump with pressure reducer, feeding the M2 rack. Ignition switch is mounted in dash, but no reason you could not mount on column if you choose ( or go with one of those fancy push buttons ! ) | | |
