Originally Posted by 4-5-6 Chevy Trucks
The "Numbers-Matching" cliche, is often used, when referencing these trucks. Unlike the car-counterparts of the same years, which included trim tags, indicating the R.P.O.'s of the vehicle, the trucks of the same years, did not have trim tags, therefore "Numbers-Matching", is not applicable. Without the orginal build sheet, window sticker, dealer invoice or protect-o-plate (with database access), the Regular Production Options, found on the truck, as it was originally equipped, is virtually impossible to verify or prove.
Tony; would this made it a matching nbrs truck?
http://imageshack.us/photo/my-images/803/img00416201208221518.jpg/
http://imageshack.us/photo/my-images/696/img00411201208221044.jpg/
the protecto-plates of those years would not have had data - base access as that was not in effect yet. it was all manual paper type research and access.
the line setting or build sheets with the corresponding ser # was the only real reliable way of identifying what they had
ron
