Wanting better hiway gears I just picked up a dana 60 with a 373 ratio from a 71 F250. The WMS is 3/4" wider than the stock Eaton so should work well. I do need to move spring perches and shock mounts. Do I need to have the housing aligned after welding the perches? I have read conflicting opinions on this.
