Trying to rebuild my oil pump but can't get the top of the pump that holds the shaft and gears in place off. Looked in the service manual and searched the site with no luck. I removed the four bolts but I'm affraid to force the top off. 53 216 engine.
Thanks in advance
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
