| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#9214 01/15/2003 12:14 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | oldbluetruck,
I used lengths of copper wire to test several different ways of running the lines. Even then, I scratched my head for a few days before settling on the routing in the picture. Most likely it is not as it was originally run (Fred T - thanks for looking for a diagram/picture - post it if you are able to find it).
On a 1/2 ton truck with standard fuel pump, the fitting on the intake manifold is a hex-sided plug with with a 2-3" pipe/tube that is bent at a right angle and directed towards the firewall. A rubber line/hose was originally used from the fitting on the intake to the wiper motor.
The vacuum line fitting on the intake manifold in the picture came off an intake manifold from either a larger truck or a truck that had a dual-action fuel pump. Some of the larger trucks had metal lines with flare fittings.
I agree with you that you should be able to find a brass or steel fitting to use on the manifold. Most likely you will not find a single piece to work but a reducer/adapter-or-two should do it.
Tim | | |
