| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 13 New Guy | | New Guy Joined: Feb 2013 Posts: 13 | This is a picture of what I am given to believe is a reversing switch on the starter. It looks like is has been taken apart/bypassed, and used as a ground. It has a wire attached to the firewall, and the other wires on the right side go to the distributor. What do I do with this contraption when I convert to 12 volts??
[IMG
1947 AD, 1.5 ton, 216 If you can't fix it with a hammer, you've got an electrical problem! | | |
