| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Does your truck have 10 hole stud piloted wheels? Otherwise you will probably have to get custom wheels made. They are not going to ride good because you need to keep 100 psi in them. These are what we call lopro 24.5. I run lowpro 22.5. I buy a lot of tires from this guy. http://www.worldoftires.com//index.php?cPath=43_45If you have Michelin or Bridgestone in mind, add about $200 per tire. | | |
