Should be numbers cast into the side of the block either by the starter or by the fuel pump.These numbers will be a raised casting (part of the block)
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
