crawlerman - your rear axle is probably a 5.73:1 ratio. The 5 lugs on the rear are most likely adapters bolted onto the original 8 lugs. Mine has 6 lug adapters, and one side is left hand thread and the other is right hand thread. Not sure if yours are set up the same.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
