0 members (),
90
0
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is not uncommon for the disc to rust tight to the flywheel and pressure plate. If you jack up one wheel, start the engine with it in gear, step the clutch pedal to the floor and hit the brakes it usually breaks it free. Or if you are in a place where you can start it in gear do that and goose the gas a few times with the clutch to the floor, that also works.
See the USA in your vintage Chevrolet! My Blog | | |
