| | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91361 03/06/2002 1:35 AM | Joined: Jan 2002 Posts: 2,840 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,840 | I guess it could be worse.....
Recently converted from 6 to 12 v.
Just overhauled my rear Stopray's (cleaning out the rust, rewired the sockets, etc.) First tried the brakes and BOY ! they're bright. Tried the tail lights and nothing !!. Disconnected the wires to the tail lights and checked the wires for life with the headlight switch turned on. Strong 12 volts.
Re-connected the taillights, inserted the bulbs, nothing.......
Is it possible that when installing the bulbs that so much force is being applied to the wire conductor underneath the bulb that it's somehow pressing the wire to the light box itself causing a short ?
Isn't it odd that both tail lights have identical symptoms ?? And yet both brake lights are brighter than the moon on a clear night ???
I'm now questioning if the problem is really in the back ? Can it be that the problem is maybe somewhere upfront though is not apparent when you simply run a volt meter at the back ?
Any words of wisdom would be greatly appreciated....
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
Entire Thread
Brakelights work, Taillights dont
| cmayna | 03/06/2002 1:35 AM |
Re: Brakelights work, Taillights dont
| acme | 03/06/2002 9:55 PM |
| Fred T | 03/06/2002 10:18 PM |
| cmayna | 03/07/2002 1:46 AM |
| Curly | 03/07/2002 4:43 AM |
| cmayna | 03/07/2002 3:45 PM |
| Fred T | 03/07/2002 10:08 PM |
| Curly | 03/08/2002 12:41 AM |
| cmayna | 03/10/2002 2:50 AM |
| Tony M | 03/10/2002 6:13 PM | |
