| | | Forums66 Topics128,060 Posts1,055,833 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Depending on your turn signal switch, you either have a wiring error in the switch or you have switched the brake light wire with one turn signal wire.
Re-examine your wiring diagram. You will find the issue.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
Entire Thread
52 Chevy with a slight electrical problem,
| kahoys | 01/20/2013 8:59 PM |
Re: 52 Chevy with a slight electrical problem,
| di1953gmc | 01/20/2013 10:32 PM |
| di1953gmc | 01/20/2013 10:43 PM |
| kahoys | 01/26/2013 5:16 PM |
| Cletis | 01/26/2013 10:44 PM |
| kahoys | 01/27/2013 7:36 AM |
| Cletis | 01/27/2013 12:11 PM |
| kahoys | 02/14/2013 6:33 PM |
| MNSmith | 01/27/2013 9:42 AM |
| FriedGreenTmater | 02/14/2013 6:41 PM | |
