| | | Forums66 Topics128,089 Posts1,056,418 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91315 05/21/2004 6:18 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | cmil, have you checked the voltage your alternator is putting out? A high voltage will not be good for the battery. I suppose you could run an alternator in a +ve ground set-up but you might have to isolate the alternator and run the case to the -ve side of your wiring system and the output to the +ve ground. | | |
