I have used the EZ kit sveral times and it has worked fine for me. The unit is a lot like an OEM, in the way the wires attach to the fuse block, no clips or screws. It's labeled nicely and has plenty of wire length. If you have been checking around you know the pice is right. The only bad thing is that the instructions are a little weak. They may be better now, (this was 2 years back) they seemed to know then that they were soft in that department. All in all I would use them again, if only for the price. Good luck Richie Z
