7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The only place rivets might be is to rivet between the rim and the center. If they have to be replaced, I would drill out the holes to a standard size hole and order some steel rivets from someone like these guys. http://www.bylerrivet.com/products/solid-rivets.aspx?cat=41I am in the trucking business and we set rivets all the time. A semi trailer repair shop should be able to buck the rivets for you. They probably wouldn't have steel rivets on hand. Only aluminum. But you would want steel. | | |
