I don't quite understand the upsidedown question. Far as I can see there is only one way that assembly can go back together. What I ended up doing was I oversized the holes in my rear end that fit the pin in the spring. It did not take much to get the front of the tube to move over 3/4' of an inch. I figured with the shackles holding everything in place that a less then perfect fit would not be a problem. It only changed the angle of my rear end by about 1/8". I think the problem is the frame may have been slightly bent which caused all of this. It is all together now and staying that way.
If you never tell a lie, you never need to remember what you said.
