1 members (Gdads51),
100
2
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | I've had the same problem on two different trucks and here's how I got them off.
I have a 5 foot long 3" heavy wall pipe that I use as a slide hammer. I lay under the truck with the pipe supported by the leaf springs and hit the lip of the brake drum with the open end of the pipe like a big pile driver hitting it a few times at 3 o'clock and then a few at 9 o'clock. You'd be amazed at how much emergy is excerted with that 40 pound pipe...something will give. Got the job done both times with no broken parts (me or the truck).
Mike B :) | | |
