Not many options to improve the rear end gearing on the 3600 and 3800, you either have to change out the entire rear axle assembly for a later model rear, or try to find the increasingly rare (and very desireable) 4.10 ratio 3rd member from the '68-'72 C20. There is one other option as well, changing out the transmission for one that has an overdrive final ratio.
