| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | something affected by heat - or by the small steady vibration of the engine operation .... sounds like a general light circuit problem, so maybe a main connection on the light switch, like the thermal 'circuit breakers' on the switch, maybe weak springs there, make sure all the plug on connectors are quite tight
Bill | | |
