| | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have removed a torque-tube rear-end by following this procedure - the procedure I think you are moving towards:
- raise the rear of the truck so that the rear wheels are about 1" off the floor - place jack-standsunder the the rear frame rails, forwards of the rear spring mounts - place a rolling floor jack under rear end and raise to the height of the rear end - disconnect the springs from the rear axle - disconnect the rear shackles - place a rolling floor jack under the torque-tube - lower the rear end and slowly/carefully roll it backwards - support the torque tube so that it does not drop
This is a two person undertaking.
Entire Thread
Shattered Yoke Question, Driveshaft Problem.
| 53John3100 | 12/30/2012 3:19 PM |
Re: Tourqe Tube, Transmission or Rear End problem?
| tclederman | 12/30/2012 5:08 PM |
| 53John3100 | 12/30/2012 5:25 PM |
| Forty9 | 12/30/2012 6:21 PM |
| 53John3100 | 12/30/2012 7:11 PM |
| SWEET | 12/30/2012 10:38 PM |
| 53John3100 | 12/31/2012 8:48 AM |
| SWEET | 12/31/2012 9:59 AM |
| 53John3100 | 12/31/2012 10:24 AM |
| tclederman | 12/31/2012 11:05 AM |
| 53John3100 | 12/31/2012 11:13 AM |
| 53John3100 | 01/02/2013 12:27 PM |
| Forty9 | 01/02/2013 12:53 PM |
| 53John3100 | 01/02/2013 1:11 PM |
| Forty9 | 01/02/2013 4:52 PM |
| 53John3100 | 01/02/2013 5:03 PM |
| 53John3100 | 01/02/2013 6:40 PM |
| mo2cyl | 01/02/2013 7:06 PM |
| tclederman | 01/02/2013 7:19 PM |
Re: Shattered Yoke Question, Driveshaft Problem.
| DADS50 | 01/03/2013 3:30 PM |
| jorb | 01/05/2013 3:48 PM |
| 53John3100 | 01/05/2013 7:40 PM | |
