| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 27 New Guy | | New Guy Joined: Dec 2012 Posts: 27 | the rocker needs to go in so the fender gap to rocker is correct you need the door installed & fitting the cab perfectly first to get the proper gap from bottem of door to top of rocker & so the in & out positioning is right allso i use weld through primer on all inside areas of the cab & rocker so when your done you dont have bare welded steel trapped inside were you might not be able to get a corrosion ressisance coating the key to long lasting repair is to seal the metal on all sides from air water etc..
just sand it a little more 47 1st series pu 4x4
