| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ol55 - the switch Brad linked is the one that mounts inside the cup of the 55-59 signal assembly - under the wishbone spring on the right - if that's the unit [factory] you have, not canceling fully could be to do with the springs in the cup or excess wear at a number of points, as well as a worn out switch Bill | | |
