0 members (),
146
2
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 21 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 21 | I have been through the stove bolt forums and Mike's carburetor site and gained much knowledge. My specific question is regarding the throttle body for my YF carb which has a cast 788 on it. The holes at the bottom of the throttle body which meet the insulator are approx 11 o'clock and 2 o'clock whereas most photos and the gaskets in rebuild kits put them at Appx 11 and 1 o'clock.
When I took the carb apart I noticed the gasket actually covered the hole at 2 oclock and there is no groove in the insulator to allow fuel out this hole and into the manifold. Should I make a custom gasket and use my dremmel tool to open this up or just slap on the gasket and cover this hole...
1951 GMC with positive ground. Engine is a ‘54 Chevy passenger car (Serial Number 0024472F54Z) with a ‘56 head (casting code on top of head 3836848 GM 4), Casting Code (on passenger side on side of head B56 848 850)
