7 members (GRNHydra, Forty9, Shardean, Ponchogl, SWEET, 78buckshot, Stovebolt48),
77
Mod | | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90264 01/12/2005 3:13 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Be aware that though popular the diode solution does have a down side.
There is about a 1/2-volt drop across the diode, and this means the alternator is not correctly reading the battery's charge.
As a result you could have some battery issues. I'd not expect it to be a problem if you don't drive the truck much. If you use the truck frequently I'd expect it to decrease battery life because the battery is always being over-charged.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
