The main ignition power wire, in your case the wire from your fuse box, should have a ballast resistor inline on its way to the coil. The wire from the starter to the coil bypasses the resistor for a hotter spark during starting.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
