matt55,
Would you please post the engine ID that is pressed into the block just to the rear of where the distributor goes into the block? And, please post the (
block date casting-code).
Also, please let us know at kind of lifters you have.
Most 235s with Powerglide transmissions had hydraulic lifters (as noted by DMGfifty); however, all other truck 235 engines had mechanical lifters. The 1960 truck specifications manual and Truck Data Book do not seem to be not clear about which style lifters were used in the 235/Powerglide truck combination. All 1958 and later 235/261 blocks were drilled for use with mechanical and hydraulic lifters.
