| | | Forums66 Topics128,140 Posts1,056,467 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the body of the item is the 'ignition switch', the part that you've removed is the 'lock cylinder' .... just push it back in the hole in the same orientation as you pulled it out, if you haven't messed anything up it just seats itself in
Bill | | |
