7 members (RoadsScholar, Hanks custodian, thekid1950, Peggy M, Hotrod Lincoln, dt235sd, Thomaslb),
193
2
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure you have heavy enough battery cables. Is the mounting area for the starter painted? If so you might want to clean things up so the starter can get a good ground. Does the truck spin good without the ignition turned on? | | |
