Using a 12 volt wiper motor from a Volkswagon GTI I have begun to convert my '51 to electric wipers. The hardware set up is finished and now I am set for the wiring. My problem is that I am not sure how to proceed. The colored input wires to the motor assembly are: brown,green, green/black,green/yellow, and black. This connection mates with two wires, red and green, which go directly to the motor. The red wire on the motor appears to align directly with the green/yellow on the input plug. The green wire on the motor appears to align with the green on the input plug. How do I wire to the input plug? I'll be coming from my fuse block to the input :confused: plug. Are some wires not connected?
