Thanks for the kudos, Roadmarks.
When converting the '60, '61 & '62 Chevy truck, factory six cylinder (235 cid) motors,to power steering, the challenge is locating the correct power steering pump mounting brackets. The 230, 250 & 292 six cylinder power steering pump mounting brackets are not the same and are not interchangeable, for use on the 235 sixes. That will be the challenging assembly to locate.
Our kit is specific for the '63-'66 Chevy truck 230, 250 & 292 six cylinders.
