Okay... from crusing the past posts it looks to me like I can't use the IC9 6 volt coil, but need the IC64 12 volt one instead... the guys at Napa are getting to know me really well.
So my question is, since my truck was converted from a 6 volt system I have the external resistor on the firewall... since I am going to be installing a coil with an internal resistor, what do I need to do to eliminate the old one?
