2 members (baldeagle, Oswald),
42
10
Mod | | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89651 09/30/2004 12:05 AM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | I am putting one of my 69 c-10s back together and was told that the voltage regulator should not touch (metal to metal)the radiator support. I found that everyone agreed with this so I bought the "voltage regulator bolts" that are insulated and made a gasket to mount my regulator. Here's where I became puzzled. As I was connecting the wiring harness, it had a wire from a sheet metal screw on the base of the regulator to the radiator support. Should I leave this wire unhooked?
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
