| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89648 04/29/2002 5:42 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | That motor takes a 180 degree thermostat, so if you put the hotter sensor on it, your fan will probably run all the time, because the engine won't be cooled down enough to close the thermostat.
If you put the lower temp sensor, it will only run when the thermostat is open, which means the engine *needs to be cooled. Therefore I'd choose the On at 186 - Off at 161 sensor. | | |
