Hi I was wondering if someone can tell me what engine I have I just bought a 46 1/2 parts truck
but it appears to have a different engine than my other one that has the origional engine in it which has the same # on the block behind the distributer as on the vin tag
this engine has no # on the block behind the distributer and has larger spark plug holes other than that it looks identical the block # is 369337 with gm 48 stamped under it the head # is 838773 can anyone give me a heads up on this thanks
