| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I plug my compression gauge into an air compressor line occasionally to compare its reading to the tank gauge. 80 PSI translates to about a 5.5:1 compression ratio, which is a bit low, but a lot of the time low cranking speed and/or slightly sticky valves can combine to give a somewhat lower than accurate reading. Jerry
